04 5.7l shaking when braking!!!!
Old Jan 17, 2010 | 04:54 PM
joe328's Avatar
joe328
Exclamation 04 5.7l shaking when braking!!!!
I have a 2004 dodge ram 5.7L single cab truck only has 50000 miles on it and I ran into some stopping issues. I replaced all of the brakes front and back, but when I got to the passenger side rear brakes I noticed that there where little chunks taking out of the piston on the calliper. I replaced the calliper along with new washers for the hose and rebleed all 4 corners of the truck and I still have stopping issues. When I begin to apply pressure the truck starts shaking really bad, and I know most would say it is the rotors, but its not I check those as well. So this is where I am at and I am not sure what else to do. I would like to get this fixed myself so I can save some cash. I will take all the help that is given. Thank you in advance.
Old Jan 17, 2010 | 05:28 PM
cwboyjohnny24's Avatar
cwboyjohnny24
So you said you replaced all of the front brakes...What exactly did you replace? What all did you change out on the back of the truck?
Old Jan 17, 2010 | 05:43 PM
Pyro's Avatar
Pyro
I Beat Tetris
Are the calipers and pads mounted correctly and securely? If they're vibrating it could cause uneven braking and the shake you are describing.
Old Jan 17, 2010 | 05:46 PM
joe328's Avatar
joe328
I changed all of the brake pads on all four corners and the calliper on the passenger rear brake. along with bleeding them all to assure no air in the line. I did install right they only went on one way. I have talked to some people and they where saying maybe the shock, but that wouldnt make sense beause I should feel it at all speeds.
Old Jan 17, 2010 | 05:53 PM
cwboyjohnny24
I know you checked out the rotors, but I'm thinking one of the rotors is out of round, possibly that one on the back that you had problems with the caliper. You may not notice it just running your hand over them. You may want to take them off and have them turned at a machine shop or buy some new ones. We have a napa that will turn rotors for I think 15 bucks a piece around here in FL, but I bough new front rotors not too long ago and I think they were about 40 bucks a piece. If you have an out of round rotor and you put new pads on there it will shake because the old pads had worn to the shape of the rotor where the new pads haven't and aren't making full contact. Just a thought.
Old Jan 17, 2010 | 05:59 PM
BEAR's Avatar
BEAR
Old Jan 18, 2010 | 09:04 PM
joe328's Avatar
joe328
Ok I want to add that this truck was sitting for 12 months while I was away. When I got back I drove it for about 3 months and all of a sudden this started to happen. I was wondering if there was any other thing that it could be if resurfacing the rotor did not work? Thank you in advance.
Old Jan 18, 2010 | 09:11 PM
cwboyjohnny24
To be honest I don't think so. If you bled the brakes, the fluid has moved. I think I'm gonna stick with the rotors. The only other option is a sticking caliper.
Old Jan 18, 2010 | 09:36 PM
joe328's Avatar
joe328
I am going to go get that rotor turned tomorrow, but I replaced the calliper already and still shaking, so I will postif the turning worked or not.
Old Jan 22, 2010 | 09:34 PM
joe328's Avatar
joe328
Default New worries
Ok, I said I was going to take the rotor off and get it resurfaced, however; I figured that getting a new rotor with a new calliper and brakes would be best. Now I tried to do this today and I could not get the rotor off and I do not understand why? Along with trying to do that I noticed that the WEEK OLD calliper that I just put on had a chunk taking out on it. I am not understanding why this could have happing so quick.
I was thinking maybe me not being able to get the rotor off could have something to do with this. That the rotor was sticking still when I try to brake. Anybody have any ideas about this thought please let me know. Thanks in advance
