Leveling kit causing my steering wheel to wobble?? HELP
Old Jan 22, 2010 | 04:29 PM
  #51
cwboyjohnny24's Avatar
cwboyjohnny24
that's why I'm looking at the rough country if I was gonna get a lift. They have a 6" spindle lift for $900. That's what oefootball is running.
Old Feb 19, 2010 | 02:11 PM
  #52
ckeri26's Avatar
ckeri26
i had this problem when i bought my truck. my steering wheel would woble. i thought it was my aLIGMENT but after a while when i got new tires. i noticed one of my tires were bad.. meaning that there was a wear bubble starting in the middle of the tire... this mad my tire to wobble making my steering wheel woble.
Old Mar 17, 2010 | 11:48 PM
  #53
Jacob2k8's Avatar
Jacob2k8
I put a below-coil-spring spacer kit in mine and it did cause a bit of a wobble. Mine was fixed by the alignment. The lift caused the front wheels to move to \-----/ positions... causing the stock goodyears to wear on the outside trim. The angles were .51 degrees left wheel and .71 degrees right wheel. It was fixed up when i put the new set of Cooper Zeons LTZ (275/60R20) on and had an alignment. By the way the tires, alignment, and install were 763.40$ out the door at Kauffman Tire.
Need to get new pictures of it since lift and new tread.
Old Mar 18, 2010 | 08:12 AM
  #54
frvdodge's Avatar
frvdodge
dont know if it will help u ejm, but i have an 07 4x4 1500 leveled and i had to replace my power steering rack to finally get my wobble out. mine wasent a death wobble just a very slight shimmy. I have owned 4 of the 2nd gen 2500 or 3500m sa diesels before i got this hemi and they all had the death wobble. may not fix urs but did mine
Old Mar 19, 2010 | 01:07 PM
  #55
EJM05's Avatar
EJM05
I fixed it. I sold the truck.
