steering wheel shakes
Old Jan 21, 2010 | 12:14 AM
surfsude650's Avatar
surfsude650
New Member
Default steering wheel shakes
in my 04 1500 my steering wheel shakes a little bit only at low speeds and only when the wheel is straight. it does it while accellerating but gets very faint at around 60mph i had an alignment less than a month ago the tires looked fine any suggestions
Old Jan 21, 2010 | 12:15 AM
surfsude650
New Member
and btw i just got the truck not sure if it was doing this the whole time or not
Old Jan 21, 2010 | 12:22 AM
mmstar23's Avatar
mmstar23
what tires are you running?
Old Jan 21, 2010 | 12:24 AM
surfsude650
New Member
stock 27560r20's
Old Jan 21, 2010 | 12:26 AM
rcman0056's Avatar
rcman0056
Tires are probably worn from being out of line before you had the alignment. Only new tires or a rebalanced will fix that. Try rotating your tires around. front to back. back to front.
Old Jan 21, 2010 | 12:31 AM
mmstar23's Avatar
mmstar23
exactly what im thinking...the only thing that i can think of that would make it shake at lower speeds rather than high would be the tread, which is why i asked what tires they were, some very mud dedicated tires can do this, or bad cupping of stock tires can do this too. maybe someone else will know for sure, but im almost positive it because your tires are out of whack and your best bet is new ones....
