Amp and Speaker mod
Old Jan 21, 2010 | 11:30 AM
j_bugman's Avatar
j_bugman
Default Amp and Speaker mod
I have the navigation display and stereo in my truck. Does anyone know how to get it out to connect the wires for the an amp and speakers without breaking all of the front paneling? I have the accessories and would like to use them but am not sure of how big of a job it will be or if I will be able to do it myself. Any help would be great!!!
Old Jan 21, 2010 | 01:29 PM
nim81's Avatar
nim81
taking the dash apart should be fairly simple, a couple screws and a good pull to relase the clips. as far as hooking up wires for an amp, i know they make a rca splicer that you can run off oem speaker wires.
Old Jan 21, 2010 | 03:29 PM
Brokenpath's Avatar
Brokenpath
https://dodgeforum.com/forum/3rd-gen...stall-diy.html
Old Jan 22, 2010 | 10:26 AM
bigmac18's Avatar
bigmac18
Yep, just tap into the front speaker wires behind the kick panels. You will need a line output converter. It basically converts the speaker wires to RCA wires to plug into your amp. Unless your amp also has line level inputs, then you can just attach the speaker wire directly to your amp.
