Proper Wiring of Air Compressor
Old Jan 22, 2010 | 11:46 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I see your battery, tank, compressor and air valve, but where is the horn at in that drawing and its wiring? LOL
Nice drawing BTW though.
Old Jan 28, 2010 | 08:42 PM
caliboy@heart's Avatar
caliboy@heart
Originally Posted by weedahoe
You are going to need a standard SPDT 5 pin relay if it does not come with one. You will also need a 5 pin harness if you can find one but if not then get some INSULATED female spade connectors. The relay is a 30/40 amp (depends one how you wire it) and can be found at most audio shops and aut parts stores.
This will help pretty much no matter what compressor you have
http://www.viaircorp.com/OnRoad/Sche...singlec_wd.pdf
So where is this relay actually placed? In the fuse box?
Old Jan 28, 2010 | 10:04 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Usually close to the compressor somewhere but really where ever you want to put it.
