What is this annoying noise?
Old Jan 24, 2010 | 02:53 PM
Mike649's Avatar
Mike649
Question What is this annoying noise?
My truck has developed some sort of annoying noise. I cannot figure out what is causing it, perhaps one of you will have some tips.
The radio needs to be on very low or off to clearly hear the noise. It sounds like it is coming from the Front Passenger side. It makes noise when hitting small bumps or anything of that short. Sounds most like it is coming from outside on the chassis/suspension somewhere. Any ideas?
Old Jan 24, 2010 | 02:58 PM
BadHab1t's Avatar
BadHab1t
its hard to tell when we cant hear it....bad ball joint or tie rod? can you explain more into detail....
Old Jan 24, 2010 | 04:09 PM
Mike649's Avatar
Mike649
I think I may have it solved. The hood was adjusted at the body shop. I adjusted the hood stoppers and the noise seems to have gone away. It's raining outside so I'm not 100% this has taken care of the issue... to be continued
Old Jan 24, 2010 | 04:13 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
If you didn't get it fixed, post up an audio clip so we can hear what it sounds like and maybe we can help.
Old Jan 24, 2010 | 07:35 PM
Albertaramfan's Avatar
Albertaramfan
I had the same issue and it was my hood as well. There was a post about it a while ago.
