Problem with my ram !!!!!
Old Jan 31, 2010 | 04:07 PM
Bi0sC0mp's Avatar
Bi0sC0mp
Unhappy Problem with my ram !!!!!
2004 DODGE RAM 1500 HEMI..
A light on the dash just came on.. kind of hard to explain what it looks like but will do my best.. its orange looks like a half circle almost and now i have lost power not as much power as before since this light has come on.. any clues??? is this something i can fix myself or do i have to take it to the shop thanks for any and all help..
Old Jan 31, 2010 | 04:42 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Which light is it? Here is the page from the manual showing all the different indicator lights.
Old Jan 31, 2010 | 08:25 PM
Bi0sC0mp's Avatar
Bi0sC0mp
its a warning light for the emissons i think if i am correct it is number 1 what is on. thinking it could be a bad EGR valve thinking of changing that and see what happens.. thanks for your help any more ideas would be great
Old Jan 31, 2010 | 08:28 PM
JoeHemi's Avatar
JoeHemi
Need to get it tested..take it to autozone/advance/shucks/etc and have someone scan it and then post the code here.
Old Jan 31, 2010 | 08:42 PM
cwboyjohnny24's Avatar
cwboyjohnny24
That's your check engine light I do believe my friend. Do the key code so you don't have to take it to autozone to have it tested:
https://dodgeforum.com/forum/3rd-gen...ine-codes.html
Get the code, then either post here or check the search function for your code.
Old Jan 31, 2010 | 08:45 PM
Off_Road_Teacher
Number 1 is the check engine light. Pull the code and check it with the list of codes.
Old Jan 31, 2010 | 08:51 PM
cwboyjohnny24
Not to be mean by any means. That is an outline of a motor, not a half circle.
Teach, great visual for the dashboard, good thinking on that one!
Old Jan 31, 2010 | 08:53 PM
Off_Road_Teacher
Thanks, I like to try to get use out of my service manual whenever I can
Old Jan 31, 2010 | 09:00 PM
JoeHemi's Avatar
JoeHemi
Also, the "key trick" is a good idea to try first to get a code. I think it only works on mid 04s and older. My 04 does not work with the key trick and I need an OBD II scanner to scan for the code.
Old Jan 31, 2010 | 09:01 PM
Off_Road_Teacher
Needing a scanner to pull a code is always a great excuse for buying a tuner.
