Who on this board is bagged?
if your 2wd the front is simple....... keep your lift part tho and just remove the spring weld in a flat plate on the lower ca and the weld a bracket to the frame and done. It should take a 3-4 hours to do the front at most if its 2wd. its simple. the back takes a while tho
But even with the rear, I though it was about the same from what i was reading but just with different bag mounts. I was looking at a bolt on 4link.
The plumbing of the lines and wiring is easy to me. Thats nothing at all. Just the mounting of the bags and shock mounts are confusing to me.
http://www.youtube.com/watch?v=113idGk4Sis
http://www.youtube.com/watch?v=KaZ9b_7EZaQ
http://www.youtube.com/watch?v=qJpoEnJIzt8
http://www.youtube.com/watch?v=NDs8-oogLFg
mad chicks in this one....for you guys....
http://www.youtube.com/watch?v=QcBtcqkWthQ
http://www.youtube.com/watch?v=-b2tRttOF4g
ive got pics of this truck finished with all speakers and stuff at local tampa show....
http://www.youtube.com/watch?v=L1iZ7BbzCnY
http://www.youtube.com/watch?v=_lyK6AY9j3w
http://www.youtube.com/watch?v=htH_Lr48aLg
heres a few i know it may not be some of yalls cup of tea but it gives an idea what slammed out truck is ....now what weed is going for is something different and really hasnt been touched on enough....
remove your front springs jack it to the hight you want it at to get a plate made for the lower ca and then bolt a bag to a upper bag mount collapse the bage and tack the bracket wherever it sits. then gusset it a bit. make sure you can fit 3 fingers all they way around the bag so it wont rub then air it up. as long as everything is good and it goes up and down weld everything in realisticly u should be able to do the front for under 300 without the air management.
theres nothing wrong with hopping on bags..... they will not blow if u have the right ones and are set up right.... i have done it for 4 years and the same bags
here yah go from the shop i deal with
http://www.youtube.com/watch?v=mxBL-QoRHyI
http://www.youtube.com/watch?v=81mBS...9ADBC&index=35
