alignment
Old Feb 1, 2010 | 05:04 PM
aasbury312's Avatar
aasbury312
Default alignment
just got my level kit installed but the shop said it didnt need to be aligned cause its only 1 1/2" is that right?
Old Feb 1, 2010 | 05:36 PM
HammerZ71's Avatar
HammerZ71
I would say they are dead wrong. I put 2" coil spacers on my Jeep and you wouldnt believe how bad it caused a toe in...
Old Feb 1, 2010 | 05:42 PM
Pyro's Avatar
Pyro
I Beat Tetris
No, you need an alignment, any modification to the suspension will cause it to go out of alignment, may not be a major change, but it will be enough to cause premature wear on your tires.
Old Feb 1, 2010 | 05:43 PM
dirtydog's Avatar
dirtydog
Moderate User
They are morons. lifting the front suspension changes the entire geometry.
Get it done by a qualified 4wd shop or you will have excessive wear on your tires in no time.
Old Feb 1, 2010 | 05:44 PM
tuned93's Avatar
tuned93
yeah... you should take it to a DIFFERENT shop to get an allignment haha
Old Feb 2, 2010 | 12:28 AM
aasbury312's Avatar
aasbury312
thats what i thought and i even argued with the guy but he was convinced
Old Feb 2, 2010 | 12:37 AM
tuned93's Avatar
tuned93
no, he is retarded..
Old Feb 2, 2010 | 12:55 AM
wyseguy77's Avatar
wyseguy77
Listen to these guys, they will always steer you in the right direction.
Old Feb 2, 2010 | 06:45 AM
butch1581's Avatar
butch1581
Just think......there are tons of people that are jobless or laid off, and this idiot is still working!...........bring it somewhere else as said before.
Old Feb 2, 2010 | 07:24 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I can tell you when i leveled mine it needed an alignment.
After I added spindles I needed an alignment
After i added lift springs i needed an alignment
