2 questions, please help!!!
1. Could I install a cutout with my exhaust just being changed to flowmaster 50 series HD. It is SI/DO I have read and researched about them and I really want to install one, even just for the sound.
2. Homemade intake....What do I need to do with the hose that is connected to my stock intake. After installing one I make there will be no where to connect it. Also do i need a 4-3 reducer th come from the throttle body or should I install it to the hose that comes from the throttle body. Thanks for the help.
2. When you say install it to the hose that comes from the throttle body are you referring to installing it onto the stock intake?
Teach is spot on (as usual) with question #1. as for the homebrew CAI, i think he's gettin rid of the hemi hat and wants to know how.
BamaRam theres at least one or two really good DIY in the FAQ section
thanks for the info. I will check out the f.a.q. section. I have a seperate 1/4 hose that is also conected to my stock intake and when i put the homemade one on i dont know where to install that line to.
