New Terra Grapplers to small? Opinions, Options
Old Feb 3, 2010 | 07:51 PM
Doc Fluty's Avatar
Doc Fluty
i dunno.. the size he chose is a 32.2" inch tire.. thats a pretty stock size.
even my 24s with 33" tires is only a 2.4% taller tire
maybe the big gap in the wheel well is making them look smaller.. maybe you could lower the back end to level the truck out?
i dunno... it depends on how much 2.4% more is worth to ya to see if you wanna upgrade
Old Feb 3, 2010 | 08:12 PM
nim81's Avatar
nim81
it was worth it to me! it doesnt sound like much but that little 2.4% can make a big difference in the appearence dept. and a lil more ground clearance.
Old Feb 3, 2010 | 08:18 PM
Doc Fluty's Avatar
Doc Fluty
well its worth it to me too.. thats why i went 24s instead of 22s... but is it to HIM
Old Feb 3, 2010 | 08:39 PM
4matty3's Avatar
4matty3
take a pic of the side so we can see the entire truck if u could. i think it would help alot. plus im going to get the same tires either stock or 285s, so picks could help
Old Feb 4, 2010 | 01:49 PM
HOPTOAD's Avatar
HOPTOAD
Here are the side pics.. sorry it took awhile. I didnt realize until I went to post that the front wheels are turned. I will take a second picture with the wheels straight ASAP.
Old Feb 4, 2010 | 02:11 PM
cyclone429's Avatar
cyclone429
okay..lesson in tires.
Sknny tire give more traction than a fat tire, a smaller diameter tire gives you more traction than a larger diameter tire, model T and jeeps could go anywhere, more traction in a smaller contact area, once you increase diameter and widith, your creating more contact area that has more potential to lose traction.
a 265 to 285 is not that extream, but nothing wrong with a 265, GM trucks are running 245 diamter tires.
Old Feb 4, 2010 | 02:18 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Hmmm, I'm not wanting to cause a debate here over anything, but on some parts here, I would disagree with you. If a skinny tire gives you more traction than a fat tire, why do dragsters, etc. run such a wide tire??? More contact patch so as not to slip. If you go offroading you would want a tire with a wide tread and a tall sidewall so if you air down you have a larger "footprint". I would rather have a larger tire as far as height and also width if I'm going to be doing any offroading. You need a larger contact path. Otherwise professional rockcrawlers/off road teams would be running bicycle tires if this was true. Again, not wanting to cause a debate, just my 2 cents.
Old Feb 4, 2010 | 02:35 PM
Fav40's Avatar
Fav40
Skinny tires work better for snow plowing/driving. Street and mud you can benefit from width.
Old Feb 4, 2010 | 06:13 PM
cwboyjohnny24
To be honest with you, the more I see that picture they look smaller than 265's. Almost like a 245???? Oh, well. Sorry OP if you're not happy with 'em.
Old Feb 4, 2010 | 06:31 PM
4matty3's Avatar
4matty3
yeah they do look a little small, but no reason to be disappointed they are good tires
