gas mileage power
Old Feb 6, 2010 | 04:57 PM
vanmarlo's Avatar
vanmarlo
Default gas mileage power
I have an 03 ram 4.7 4x4 used to get 13 to 18 mpg now I get 13 or less I have an obvious power loss when the outside temp is above 80 degrees. I've done all maintenence, tune-ups, no codes everything appears normal except mpg and power any ideas what the problem is? any help would be apppreciated........
Old Feb 7, 2010 | 01:22 AM
lxman1's Avatar
lxman1
Site Moderator
Partially plugged cat converter perhaps?
Old Feb 7, 2010 | 02:53 AM
Thatonekidw/theHEMI's Avatar
Thatonekidw/theHEMI
Dirty EGR valve?
Dirty throttle body?
What oil are you running?
Old Feb 7, 2010 | 06:05 PM
vanmarlo's Avatar
vanmarlo
I've ran castrol full synthetic since I bought the truck new. As I wrote before its worse when its hot outside seems to run better when the temp outside gets below the low 70's anything above 80 it gets worse
