where is it?
Old Feb 8, 2010 | 12:57 AM
blackram1500's Avatar
blackram1500
Default where is it?
my truck didnt come with factory fog light so i now got them and need to know where the plug is to plug the harness into ( anyone )
Old Feb 8, 2010 | 01:02 AM
mdram43's Avatar
mdram43
right in your front bumper, its an easy find. if your an slt its there. just hop on under there in the day light. the fog kit is a simple bolt on kit. hardest part is putting the plastic pieces in, dont be nervous, just force em in, they wont break
Old Feb 8, 2010 | 01:22 AM
blackram1500
mine is the ST and i found one wire harness atached to the bumper that has a blk wire and a white/yellow stripe on it and not sure if this is the right one.
Old Feb 8, 2010 | 01:48 AM
wyseguy77's Avatar
wyseguy77
Yup. I have an ST as well. It should be on the driver side. You may need to get the comp programmed, plug em in and install the new switch to see if they work.
Old Feb 8, 2010 | 04:29 AM
RedTruck-VA's Avatar
RedTruck-VA
My 03 was not prewired for fog lights. I installed a small rocker switch on the dash and connected power from the fuse box using a relay. I actually prefer this setup as I use my fogs as day time running lights and can turn them on/off when I want. They are OEM fog lights add-on's that came as a kit which included the switch, relay and wiring harness from eBay.
Old Feb 8, 2010 | 07:53 AM
tuned93's Avatar
tuned93
i just bought an aftermarket set of fog lights and modified the factory (fog-less) bezels. ran a whole new switch and everything, works pretty good.
Old Feb 8, 2010 | 10:32 PM
blackram1500
Question
Does anyone know if or how much the dealer would charge to have the fog lights programed into the computer?
Old Feb 8, 2010 | 10:41 PM
04_ramslt's Avatar
04_ramslt
Hey just out of curiousity where exactly did you find oem fog lights? or are they the ebay version of oem
And tuned93 those fogs look pretty good. do you have any closer pics??
Old Feb 8, 2010 | 10:51 PM
blackram1500
I got my kit at the dealer for $280.00
Old Feb 9, 2010 | 12:52 AM
wyseguy77's Avatar
wyseguy77
Some dealers sell them a lot cheaper on ebay. Just take the time and look.
