TQ Converter Install Tutorial
Old Feb 8, 2010 | 04:20 PM
AF_HEMI's Avatar
AF_HEMI
very high quality pics. you had a good photographer. thanks for the write-up. really lookin forward to the shift kit one.
Old Feb 9, 2010 | 01:41 PM
OlDirtyJohn's Avatar
OlDirtyJohn
Originally Posted by weedahoe
thanks weed, exactly what i was looking for. all i was finding was the copy of the older version of the kit (no pump spring or snap ring instructions)
Im working on this write up now, should be up in a couple of hours.
also, if you choose to install this kit, you dont HAVE to drop the tranny and install the pump parts. you can just drop the pan and valve body to install those springs and the new plate. if you choose to go that route, it shouldnt take you more than an extra 45 min on top of the time it normally takes to drop the pan and refill. and it will be super easy. hardest part was the pump and the new snap ring in the input clutch.
Old Feb 9, 2010 | 02:43 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Is it worth dropping it and pulling the pump? Ive pulled trans before so its no big deal to me.
Old Feb 9, 2010 | 02:58 PM
OlDirtyJohn
yes, i believe it is. ive read a few places where guys have installed just the valve body components and been fine. but, the additional parts for the pump and input clutch are beefier than stock, and designed to withstand the added line pressure the kit gives you.
Old Feb 9, 2010 | 03:36 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Man I pulled so many BOP TH200-4r trans out of Olds its ridiculous. Im sure I can handle a little ol DR 545 trans......LOL
Old Feb 9, 2010 | 07:36 PM
OlDirtyJohn
Transgo HD2 install write up is completed and posted! why are you still reading this? get over there and check it out.
