power wire = CEL... WTF!?
Old Feb 8, 2010 | 06:46 PM
sharkhunter10's Avatar
sharkhunter10
what is this mod?
Old Feb 8, 2010 | 07:36 PM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
https://dodgeforum.com/forum/3rd-gen...ower-wire.html
Old Feb 8, 2010 | 07:39 PM
new2this's Avatar
new2this
New2This: The PW (either professionally made or custom made) tricks the PCM into thinking the incoming air is about 22* cooler that what it really is. This only helps to a certain extent before the PCM corrects itself. This only works at WOT when the truck no longer monitors AFR (open loop) and gives it a bit more pep if you will.[/QUOTE]
oo alright, thanks. would there be any benefit of doing this to my truck if i already have the K&N CAI?
Old Feb 8, 2010 | 07:41 PM
JoeHemi's Avatar
JoeHemi
I know I got one when I did it. I also added a jetscoop and the Airaid CAI at the same time though. I just did the PCM reset and everything was peachy thereafter.
Old Feb 9, 2010 | 04:14 PM
Pruitts Hemi's Avatar
Pruitts Hemi
I was just wondering if i have to have the 4.7k Ohm, 1/4 watt resistor or if a 1k-ohm 1/2 watt will work the same. Thanks Jeremy Pruitt
Old Feb 9, 2010 | 04:21 PM
HammerZ71's Avatar
HammerZ71
I dunno what the big deal is with the power wire, it fools the PCM into thinking your running 15 degrees cooler, so the PCM richens the mixture.
Why not just get a 180* thermostat and actually run 15 degrees cooler?
Old Feb 9, 2010 | 04:46 PM
OklaHemi's Avatar
OklaHemi
im glad it got worked out ken.
Old Feb 9, 2010 | 05:10 PM
RubberFrog's Avatar
RubberFrog
Hamm, it's not that it makes the pcm think the engine is 15* cooler, it makes it think the incoming air is 15* cooler. I would still love to see a dyno on this.
Old Feb 9, 2010 | 05:24 PM
OklaHemi's Avatar
OklaHemi
i never got around to doing a dyno since the windshield mount on my hyperpac broke but here are a couple of shots of the iat before and after
Old Feb 20, 2010 | 08:36 AM
Deroneill's Avatar
Deroneill
Is this with the power wire mod?
