transmission cooler leak
Old Feb 10, 2010 | 08:28 PM
cwboyjohnny24's Avatar
cwboyjohnny24
The lower one should be your power steering cooler.
Old Feb 10, 2010 | 08:30 PM
Marx's Avatar
Marx
is it cheaper, do i need a special rad for that?
SMKNRAM's Avatar
SMKNRAM
right BUT I know for sure that the top one is tranny! the bottom one is just a standard cooler, you can pick it up at any parts store. I don't think it has high pressure lines, so it should be easy to change
Old Feb 10, 2010 | 08:33 PM
cwboyjohnny24
It's of course a seperate thing from your tranny cooler. The reason you probably thought it was your tranny cooler is you use ATF fluid in your power steering for these trucks. Look up the power steering cooler and see what you find.
Old Feb 10, 2010 | 08:34 PM
Marx's Avatar
Marx
ya it as leaking red so i was like ahh tranny lol guess i should have done so research first, thanks guys
Old Feb 10, 2010 | 08:35 PM
SMKNRAM's Avatar
SMKNRAM
no sweat, good call on the pics, saved you buying the wrong thing
Old Feb 10, 2010 | 09:08 PM
cwboyjohnny24
EXACTLY. Pics are worth a thousand words.
Old Feb 10, 2010 | 09:42 PM
Marx's Avatar
Marx
should i replace the hoses when i change the cooler? i'm thinking yes
Old Feb 10, 2010 | 09:44 PM
SMKNRAM's Avatar
SMKNRAM
never hurts! it is cheap, and you will already have it all apart
