3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Thanks for all the suggestions. I have an 06 Megacab with ~75K miles that just started making the noise. Sounds like the whine of a blower. All the same symptoms: isn't affected by turning the steering wheel, louder at higher rpms, doesn't go away after warming up, power not affected. I'll try the belt suggestions.
I was having the same issue, and I just lost the belt and idler pulley on the water pump....now I have to figure out how to get whats left of the bearing off so I can replace it....all thats left is the inner part of the bearing...HOW THE HECK TO I GET THAT OFF?
