whining when accelerating
Old Feb 11, 2010 | 02:43 PM
Slip's Ride's Avatar
Slip's Ride
Default whining when accelerating
I have a 2005 Ram 5.7L hemi and there is a whining noise when I accelerate, seems to be RPM related and stops around 50 mph. Doesn't seem to affect the power and stops when you release the accelerator. Any ideas?
Old Feb 11, 2010 | 02:44 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
rear end and gears whining?
Old Feb 11, 2010 | 02:53 PM
Slip's Ride
No..sounds like it's coming from under the hood.
Old Feb 11, 2010 | 02:55 PM
JoeHemi's Avatar
JoeHemi
some cold air intakes will induce a whining noise while accelerating if you removed the engine resonator.
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
does it get worse if you turn the steering wheel when going slow? any vibrations anywhere?
Old Feb 11, 2010 | 03:12 PM
AWE Daniel's Avatar
AWE Daniel
I had a weird whining noise, turned out to be the alternator pulley bearings
Old Feb 11, 2010 | 03:15 PM
Slip's Ride
No vibrations...doesn't get worse when turning.
Old Feb 11, 2010 | 03:20 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If only at a certain RPM then i would think intake (CAI)
Old Feb 11, 2010 | 03:34 PM
Markmm0000's Avatar
Markmm0000
its definitely the bearings on something run by the belt. Prob the idler pulley or tensioner. Take the belt off the truck and spin all the belt wheels see if any make even the slightest noise.
Old Feb 11, 2010 | 04:12 PM
98cherryram's Avatar
98cherryram
It could be the belt depending on what shape its in or if its not seated correctly, I would try getting a new belt, cheap thing to check and easy first.
