Issue with Speedo and ABS/Brake light coming on.
I've discovered that When sitting at idle, my Speedo will bounce up and down from 0-to almost the 20 mph mark, then second I start rolling it works fine. Also now the ABS and brake warning lights will sometimes come on and then stay on until I shut the truck off or go off while driving. The Truck is an 03 Quad cab 2WD with a 4.7 and only has the standard rear wheel antilocks, not 4 wheel. I am assuming it has to be a ground issue. It has no effect on the drivability of the truck except for the fact it's annoying! Any help or insight would be appreciated.
Any idea on what to search to find that thread?
https://dodgeforum.com/forum/3rd-gen...eedometer.html
https://dodgeforum.com/forum/3rd-gen...-light-on.html
https://dodgeforum.com/forum/3rd-gen...r-problem.html
here's just a few......use the search button at the top and type speed sensor.
Trending Topics
speed sensor. Just happened on my rear end swap. they are fragile and like to break. It will most likely come out in peices and the bottom half will need removal with a flat screwdriver, needlenose pliers and paitence.. look in with a flashlight and make sure you can see the gears or you dont have all of the peices out. the top of the hole where it goes into will need to be cleaned of rust and debris or the o ring on the new one will not seat. Do not force it or you will break the new one. All it is is an electro magnet and the lead wires are very fine inside. if you push down on the end of the plug, the wires have a tendancy to snap off. Open up your old one when you get it out if it came out whole and you will see what I mean.
