anti slip axle
Old Feb 15, 2010 | 08:56 PM
tony0713's Avatar
tony0713
Default anti slip axle
my truck is a 03 1500 hemi and has the 3.92 rear with "anti-slip". so when i jack up the rear both tires spin together. but today, in the snow, i knew the wheels were spinning so i looked back but only one was. why would that be? why wouldnt both spin together?
Old Feb 15, 2010 | 10:13 PM
Marx's Avatar
Marx
how hard on the gas were you? good tires? are you sure both weren't spinning,
i also have a hemi LSD (anti-slip) and 3.92 and have had to use my 4wd to move in the snow, the stock lsd isnt that good i find it's only good for doing burnouts on pavement lol
Old Feb 15, 2010 | 10:30 PM
Wanderer's Avatar
Wanderer
Step on the brake lightly to provide some resistence. If that doesn't help, your LSD is shot.
Old Feb 15, 2010 | 10:33 PM
tony0713's Avatar
tony0713
well i was stuck on some snow in a parking spot and was trying to get out. yea good tires. steady throttle as i was watching the one wheel play dead.
Old Feb 15, 2010 | 11:05 PM
tony0713's Avatar
tony0713
i doubt its bad. it doesnt make any noise. when jacked up it spins the same and freely. and the truck only has 33k miles lol
Old Feb 16, 2010 | 07:10 AM
RedTruck-VA's Avatar
RedTruck-VA
If you have a LSD and only one wheel is spinning than it is not working properly.
Old Feb 16, 2010 | 08:00 AM
HammerZ71's Avatar
HammerZ71
The stock LSD is probably the single worst one on the market. Besides the fact that the retaining clips fall of and break, often causing a major failure, it often needs "help" in activating. Applying a small amount of brake with the gas is usually enough to get it working, but that said, it doesn't take much torque for the differential to start slipping.
If you need true LSD performance, get you an Auburn or a TruTrac...
Old Feb 16, 2010 | 09:11 AM
abarmby's Avatar
abarmby
+1 Hammer.
DTT all the way.
Al.
Old Feb 16, 2010 | 10:28 AM
dirtydog's Avatar
dirtydog
Moderate User
hammer said it well. Stock LSD is the worst money can buy. it's actually meant to not activate in certain situations.
Old Feb 16, 2010 | 02:42 PM
98cherryram's Avatar
98cherryram
I applied my e-brake a little bit lightly when I was in the mud one day, I wanted to test it, I didnt put my truck in 4wd I wanted to see if I could get the lsd to work, and it did, the e-brake actually activates it quite well.
