Help - Bang when driving
Old Feb 16, 2010 | 07:57 AM
tomalaina's Avatar
tomalaina
Default Help - Bang when driving
i have a 2007 hemi quad cab 4x4 Auto trans. I live on Long Island NY and yesterday to turned the corner by my house and there was snow on the road and in 2wd my tires spun and a loud Bang. i continued home and backed in to my drive way and Bang again. I drove to work this morning and it is doing it. it does it from a start at a light and driving in top gear. So not only when it shifts. it happens on turns too. Help Please. Do i bring it to the dealer or does anyone know a good place on Long Island to trust? Help Help Help
Old Feb 16, 2010 | 08:04 AM
RedTruck-VA's Avatar
RedTruck-VA
Do you have any vibration?
Old Feb 16, 2010 | 08:07 AM
tomalaina's Avatar
tomalaina
No vibration at all - just a Bang Randomly.
Old Feb 16, 2010 | 08:17 AM
RedTruck-VA
Could it be a frozen spring popping? (long shot) Maybe a ball joint? If it was a CV joint I would think there would be a vibration, same with U-joint. Dealership ($$) would be a good place to have it look at if you don't have a local shop you trust. Very hard to tell without looking at it.
Old Feb 16, 2010 | 08:23 AM
tomalaina's Avatar
tomalaina
this is all after the tires spun on a turn. i was in tow/haul mode at the time. i dont know if that locks the rear different than normal mode.
Old Feb 16, 2010 | 08:39 AM
Shiloh 24's Avatar
Shiloh 24
When the tires spun did you suddenly gain traction? If you had the tires spinnin pretty good and hit dry/unslick ground you could have effed up your u-joint or something.
Old Feb 16, 2010 | 08:48 AM
tomalaina's Avatar
tomalaina
yes it gained traction - the patch of snow was small but the tires spun pretty good.
Old Feb 16, 2010 | 08:52 AM
RedTruck-VA
Try to isolate where the popping is coming from, front or rear?
Old Feb 16, 2010 | 10:25 AM
cwboyjohnny24's Avatar
cwboyjohnny24
Check out your u joints first, then I would be tempted to start looking at your diff.
Old Feb 16, 2010 | 10:28 AM
Shiloh 24's Avatar
Shiloh 24
Going from slick to unslick like that puts a huge amount of stress on your tranny, u joints, cv's, and diff's. It could be any one if not a couple of those things causing your issue.
