The stupid CEL is on AGAIN !
Old Feb 16, 2010 | 04:10 PM
shinna202's Avatar
shinna202
Default The stupid CEL is on AGAIN !
I got the code and the problem, however I do not have the solution to them. I need help from you guys to get this thing turned off.
P0300-Multiple Cylinder Misfire
P1491-Radiator Fan Ctrl Relay Circ
P0442-Evap Leak Monitor Medium Leak Detected
P0455-Evap Leak Monitor Large Leak Detected
P0305-Cylinder #5 Misfire
P0307-Cylinder #7 Misfire
P0303-Cylinder #3 Misfire
Old Feb 16, 2010 | 04:15 PM
HammerZ71's Avatar
HammerZ71
Thankfully, a large Evap system leak can be the cause of the cylinder misfires, so tracing the Evap leak may fix all but P1491 and that don't sound like a tough one.
I have a diagram of the entire Evap system in the FAQ section may help you...
Old Feb 16, 2010 | 05:02 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can also spray a carb cleaner or suck around the hoses with the engine running to find you leaks. When it gets sucked in (if it does) the idle speed will change.
Old Feb 16, 2010 | 05:07 PM
lxman1's Avatar
lxman1
Site Moderator
I use an unlit propane torch. Doesn't make a mess like carb cleaner does
Old Feb 16, 2010 | 10:38 PM
shinna202's Avatar
shinna202
Could the misfire mean time for new head gasket?
Also did not find one for evap. system one. Am I blind?
https://dodgeforum.com/forum/3rd-gen-ram-faqs-133/
