New front speakers recommandation??
Old Feb 21, 2010 | 11:35 PM
maximedelo's Avatar
maximedelo
Default New front speakers recommandation??
Hi, I would like to replace my front speakers on my 04 Ram. I think they are 6x9... But I would like to know which speakers would you reocmmend? I have the factory infinity radio and I don't want to change it. Does anyone changed his speakers and noticed better sound than factory speakers??
Thanks
Old Feb 22, 2010 | 09:07 PM
maximedelo's Avatar
maximedelo
anyone??
Old Feb 22, 2010 | 09:35 PM
mike_r's Avatar
mike_r
Don't wanna be all mr. negative here, but the infinity system sucks. Changing the speakers will make it sound worse because the amp is tuned for those speakers. Now, If you want to change the speakers and the amp then it would sound a million times better.
Old Feb 22, 2010 | 10:07 PM
OkieDodgeTRP's Avatar
OkieDodgeTRP
I just changed mine cause the drivers door was blown. I am all about quality on amps and subs, but for door speakers I could care less...they all sound the same to me. I just bought a 70$ pair of Sony Xplodes and they fit well and sound fine on full blast.
Becareful on getting a deep set of 6x9s. The door can't fit a very thick speaker at all.
Old Feb 22, 2010 | 10:14 PM
maximedelo's Avatar
maximedelo
OkieDodgeTRP, do they sound the same as infinity's when new or slightly better?
Old Feb 22, 2010 | 10:59 PM
OkieDodgeTRP
Well I can't compare to infinitys, but I had aftermarket speakers, and rockford subs/amp in the chevy and it sounds just as good.
Old Feb 23, 2010 | 06:35 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I have an 04 with the Infinity and I replaced all of my Infinity gear in the doors with Kicker 6.5's
Old Mar 17, 2010 | 10:36 PM
maximedelo's Avatar
maximedelo
anyone would have another recommandation? Any speaker model that some tried and sounds good with stock amp?
Thanks
Old Mar 17, 2010 | 11:07 PM
kx250frider617's Avatar
kx250frider617
your pretty much SOL on just speaker replacement, unless you find another stock one but I would just bite the bullet and get a amp and component speakers, they sound a million times better
Old Mar 17, 2010 | 11:20 PM
HemiPro_05's Avatar
HemiPro_05
MB Quart, Digital Design, and Massive speakers are well known for being top notch. I have a set of 6.5 Mb quarts in the fron of mine cause the magnet was too big to fit in the whole so I made a spacer. Sounds good though. I had them playin just vocals and had 2 jl 12w7s and DD amp. Most loud system you here all you can make out is base and vibration. On mine it was loud bass and louder vocals
