Questions on 3" lift kit for 2wd Dodge Ram
Old Feb 22, 2010 | 06:36 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Yeah, I put the coils in myself. It wasn't that bad. You just have to make sure you put the coil back in the lower bucket correctly. Also, you will have to reinstall the coil isolator on the top of the coil. It's pretty straight forward. Take off the brakes, upper ball joint and tie rod end. Once you get the LCA down far enough the coil comes right out. Then reverse it.
Old Feb 22, 2010 | 06:37 PM
cwboyjohnny24
Originally Posted by cheapbeater
i thought the stock wheels had 4.5" of backspacing...? anyone know the backspacings of the 17's and 20's? that info should be in the tire faq's..
Not from what hammer told me when I was looking to put the 6" rc kit on. If I remember correctly he instructed me that none of the rims have 4.5" backspacing.
Old Jun 22, 2010 | 11:33 PM
red ram ridin's Avatar
red ram ridin
Im looking to do the same kit on my ram. Not sure on backspacing. were you suggesting it would fit fine on 5 inch backspacing cwboy? since the spindle is the same. also when you put yours on did you have to use a spring compressor?
Old Jun 23, 2010 | 01:16 PM
cwboyjohnny24
No, I didn't use a spring compressor. I had the truck up on jack stands and put the jack under the lca and dropped it slowly.
You should be able to run the factory rim on the 3" rc spring setup as long as you're not trying to run a tire too wide. I have a tire that's around 11.5" wide and barely clears the uca. The reason rc tells you to have a rim with at least 4.5" backspacing on the kit is because they're telling you to run a 12.5" wide tire. If you go with a thinner tire you should have no problems, or you could buy spacers if you really wanted the 12.5" width.
Old Jun 23, 2010 | 02:56 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
When I had stock 20s I had no issues using my original lift with RC 3" spindles. I later added 3" CST springs and 3" shackles on the rear. But not I have a total different kit and rims.
Old Jun 23, 2010 | 03:31 PM
red ram ridin
Thumbs up
Very appreciative cwboy
Old Jun 23, 2010 | 03:33 PM
cwboyjohnny24
No problem.
