Hella 500 HID Conversion
Old Feb 22, 2010 | 08:16 PM
TRXHemi's Avatar
TRXHemi
Thumbs up Hella 500 HID Conversion
I wanted an HID kit for my Hellas so here goes.....
I bought an 8000K kit made by Xentec....anyway, had to modify the housing a little bit to make room for the HID bulb.
I drilled a hole in the center to allow for the HID bulb to come out. I temporarily sealed it with electrical tape, but will replace it with a grommet soon. It turned out pretty well and the results are sweet.
Old Feb 22, 2010 | 08:19 PM
04_ramslt's Avatar
04_ramslt
man those things are bright!! looks great though. just out of curiousity howd you mount the lights where they are?
Old Feb 22, 2010 | 08:20 PM
SilverBullet08's Avatar
SilverBullet08
nice i want to do those with mine
http://www.tacomaworld.com/forum/lig...onversion.html
Old Feb 22, 2010 | 08:25 PM
4matty3's Avatar
4matty3
so all u did is drill a hole and hooked them up?
Old Feb 22, 2010 | 08:33 PM
TRXHemi's Avatar
TRXHemi
Just drilled the hole - I saw that conversion thread Bullet....I tried that but the bulb stuck out further than that guy's did. I could not get them to go 90 degrees....but what I did worked just fine.
To get those lights mounted there, I actually drilled into the front of the crossmember. The mounts come out straight. I used a longer bolt and a couple of nuts to act as spacers so it clears the AC line. The other set of lights are Hella 500ffs. They have the 85w yellow Hella bulbs in them. I may convert those eventually with 3000K HIDs.
Old Feb 22, 2010 | 10:46 PM
TRXHemi's Avatar
TRXHemi
Has anyone done 3000K HIDs? Pics?
