TRX4 guys..
Old 02-26-2010, 01:58 PM
SMKNRAM's Avatar
SMKNRAM
SMKNRAM is offline
And you realize going with a 33x10.50 is narrower than what came on your truck correct? just a lil taller but skinnier.
look at cowboyjohhny, 4.7ram they are both running 295's right now with NO issues!!
If you want to spend more money and go skinnier, then go with 33x10.50, if you want a lil taller and a lil wider and less money go with 295x70
  #32
Old 02-26-2010, 04:29 PM
DodgeThunder's Avatar
DodgeThunder
DodgeThunder is offline
I saw a guy with the stock 20s running 35x12.5x20 pro comp xterrains with just a level and no wheel spacers and the only time it would rub is on full crank when pulling into a parking spot or tight space.. So 17s should be the same case? Im picking up a set 35x12.5x17 this weekend if the guy gets back to me so if they rub Ill let you know..
  #33
Old 04-05-2013, 05:38 PM
JoshuaAckley's Avatar
JoshuaAckley
JoshuaAckley is offline
The preload on the front strut of the TRX4 models is different than non-TRX4 models. It's possible to use a regular leveling kit, if you change the front strut to a standard 4x4 strut. Also, the front strut has the lower mounting hole located a 1/2 lower on the mounting bracket, thus the preload difference.
Quick Reply: TRX4 guys..
