HELP! '04 Dodge Ram C-codes 67-90 and 00-00
Old Mar 3, 2010 | 03:25 AM
keeders08's Avatar
keeders08
Well the codes came up on the odometer reading when i did the key trick.
the ones I put up in the first post. 67-90 then 00-00 those are the only ones.
Old Mar 3, 2010 | 07:30 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Listen, Im repeating the SAME info again. Take the truck to Autozone, tell them the CEL is on and let them put an ODB II scanner on it and get the codes. They will be something like P0300 or C0219 and then come back here, go to the link I gave you, download the material and match up the codes from AZ to the codes in the PDF you will download in the link and it will tell you not only WHAT the issue is but also HOW to diagnose AND repair the issue.
Now trying to be mean but Ive repeated this several times and you still arent listening.
Old Mar 3, 2010 | 09:07 AM
cwboyjohnny24's Avatar
cwboyjohnny24
This thread if you read it and check out the links in it may be helpful also.
https://dodgeforum.com/forum/3rd-gen...coming-on.html
Also I agree with weed, you need to have someone with an actual scan tool to pull the code for you.
Old Mar 4, 2010 | 04:15 AM
keeders08's Avatar
keeders08
That was half my issue... couldnt find out if 67-90 meant something. And nobody seemed to wanna tell me it cant be decifered... lol
Old Mar 4, 2010 | 07:18 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you really wanna know what it means, take it to the dealer, let them hook it up to thier star scanner and then they will tell you. It is a proprietary code for a proprietary scanner. No one on this board that i know of has Dodge/Chrysler scanners.
However, if you would like to buy one, you can get them HERE
Old Oct 30, 2010 | 11:33 PM
pshea08's Avatar
pshea08
This might be what you are looking for. I have an ABS light blinking issue after I swapped out my PCM "computer" that I can get ride of. So I looked into the C-Code thing myself and found this. Like Weedahoe said, Best thing is going to see what the error codes means. I think at the end of the C-code scan it might display the DTC code. If you look at the list the 00-00 means I have no error codes. So I am still lost with the flashing ABS light. If you have a code, Then you can take that code to the list that was posted by Weed a few post ago. Hope it helps.
C-Codes
01 Airbag warning indicator output circuit shorted. Refer to the appropriate
diagnostic information.
02 Airbag warning indicator output circuit open. Refer to the appropriate
03 ABS indicator output circuit shorted. Refer to the appropriate diagnostic
information.
04 ABS indicator output circuit open. Refer to the appropriate diagnostic
information.
05 MIL indicator output circuit shorted. Refer to the appropriate diagnostic
information.
06 MIL indicator output circuit open. Refer to the appropriate diagnostic
information.
07 Wait to start indicator circuit shorted. Refer to the appropriate
08 Wait to start indicator circuit open. Refer to the appropriate diagnostic
information.
0B BTSI output circuit shorted or open. Refer to the appropriate diagnostic
information.
22 Headlamp switch input circuit shorted. Refer to the appropriate
23 Headlamp switch input circuit open. Refer to the appropriate diagnostic
information.
24 Turn hazard switch input circuit shorted. Refer to the appropriate
25 Turn hazard swiitch inpot circuit open. Refer to the appropriate
27 Courtesy/dome output circuit shorted or open. Refer to the appropriate
28 Glovebox/map lamp output circuit shorted or
open.
Refer to the appropriate diagnostic information.
29 Cargo lamp output circuit shorted or open. Refer to the appropriate
40 Wiper switch input circuit shorted. Refer to the appropriate diagnostic
information.
41 Wiper switch input circuit open. Refer to the appropriate diagnostic
information.
42 Wash/beam input circuit shorted. Refer to the appropriate diagnostic
information.
60 Passenger door lock switch input circuit
shorted.
61 Passenger door lock switch input circuit open. Refer to the appropriate
62 Passenger door lock switch input circuit stuck. Refer to the appropriate
63 Driver door lock switch input circuit shorted. Refer to the appropriate
64 Driver door lock switch input circuit open. Refer to the appropriate
65 Driver door lock switch input circuit stuck. Refer to the appropriate
66 All door lock output circuit shorted to ground
or voltage.
67 All door unlock output circuit shorted to
ground or voltage.
68 Driver door unlock output circuit shorted to
ground or voltage.
6C Driver cylinder lock switch input circuit
shorted.
6E Driver cylinder lock switch input circuit stuck. Refer to the appropriate
80 Incorrect odometer Valve found. Refer to the appropriate diagnostic
information.
81 Remote radio switch input circuit high. Refer to the appropriate
82 Remote radio switch stuck. Refer to the appropriate diagnostic
information.
A0 Internal module FLASH memory checksum
failure.
A1 Internal module bootloader failure. Refer to the appropriate diagnostic
information.
A3 Battery voltage open. Refer to the appropriate diagnostic information.
A5 TCCM messages not received. Refer to the appropriate diagnostic
information.
A7 VIN checksum error. Refer to the appropriate diagnostic information.
A8 VIN previously stored. Refer to the appropriate diagnostic information.
A9 PCI bus internal failure. Refer to the appropriate diagnostic
information.
AA PCM messages not received. Refer to the appropriate diagnostic
information.
AB TCM messages not received. Refer to the appropriate diagnostic
information.
AC ABS messages not received. Refer to the appropriate diagnostic
information.
AD FCM messages not received. Refer to the appropriate diagnostic
information.
AE ACM messages not received. Refer to the appropriate diagnostic
information.
AF SKIM messages not received. Refer to the appropriate diagnostic
information.
B0 RKE fob batteries low. Refer to the appropriate diagnostic information.
B1 RKE module communication link. Refer to the appropriate diagnostic
information.
00 Done All Diagnostic Trouble Codes (DTC) have been
displayed.
