05 ram 1500 timing
to advance or retard you would have to break the front of the engine down and change the position of the cam in ratio to the crank. There is no distributor you can turn to do it like older engines.
Who in the factory told you this?
That was a 1970's thing when they were trying to lower emissions. They retarded the cam timing 4 degrees.
You can advance the ignition timing and such with a good tuner like the Diablosport Predator. You will gain around 20hp. I love mine.
yea i have a DSP too and i was wondering about that.. been wanting to ask about messing with the timing and stuff.. how do you adjust it on the programmer? is it in the spark and fuel part? and how do you change it so you know its at it peak power?
