3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
i hoping someone could tell me if it is possible to modify a 5" lift from a 2005 2500 to fit on my 2003 1500 4x4. also if it is possilbe to use a 3" body lift from a 2001 ram 1500 sport? thanks guys
Ok as far as the lift from a 2500/3500 will not work since they use a coil from suspension and we have IFS (independent from suspension) two totally different animals. As far as the body lift dont believe it will fit but i did a quick search here http://www.performanceaccessories.com/catalog/dodge.htm and doesnt look like it will fit
yap, not going to work. you could get close to 5" lift with a body lift, cranked torsion bars, rear blocks and 35" tires... thats the cheap way anyway.
a body lift is about $325
get us some pics of that beast too
thanks for the info man. thats a sick truck you got there, thats only a 3" body and 35s?
its not that cheap man come on give me some credit. better then spending 1500+ on a suspension kit
