I need Help, and Preferably a mech who is smart!!!
Old Mar 6, 2010 | 05:38 PM
cwboyjohnny24's Avatar
cwboyjohnny24
It almost sounds like you have a vacuum leak. I would start by checking all the vacuum lines.
Old Mar 7, 2010 | 12:02 AM
HouseApe's Avatar
HouseApe
Originally Posted by Joshua1282
So I removed my valve covers and rotated the motor. Everything was working perfectly. I doublechecked all my springs and rockers. I tryed to start it again and it was still running low rpm. I have no clue.
So did you even do the compression check?
Old Mar 7, 2010 | 12:05 AM
HouseApe's Avatar
HouseApe
Vacuum leak will cause high idle and the ECM will correct it to the proper RPM (with in its limits)
Old Mar 7, 2010 | 12:32 AM
ramjamhemi's Avatar
ramjamhemi
Years ago a SBC I had with 200k+ miles on it skipped a tooth on the timing chain and it barely ran, sputtered, was hard to start, and I think because the timing was off, when you shut if off, it would fire at the wrong time and even cause the engine to spin backwards a bit and you could hear some of the cylinders leak down. Not sure if this fits your symptoms. I don't know for sure, but my suspicion is that most engines alive today will have nylon timing gears, which might make a slipped tooth possible early on in the engines life.
Old Mar 7, 2010 | 09:43 AM
Joshua1282's Avatar
Joshua1282
I don't have the capabilities to check for compression here. And I have checked for vacuum leaks. There are none. I guess the only thing I have left to check is my timing chain. Thanks guys. If y'all have anymore ideas let me know.
Old Mar 7, 2010 | 09:58 AM
HouseApe's Avatar
HouseApe
Just go buy one they are no that expensive. When you did the head gaskets do you find one was bad ?
Also did you put the push rods back in the same spot they came out of ? As the Intake and exhaust are different lengths.
Old Mar 7, 2010 | 10:06 AM
dirtydog's Avatar
dirtydog
Moderate User
Let me get this straight..... You replaced your head gaskets because of a noise you heard? What eveidence of failure did the headgaskets show? Was there obvious signs of failure or did you just assume that was the problem?
Did you replace or check your PCV valve? Did you check all the gap measurements on your plugs? It'll only take one plug to mess everything up. Does the truck idle rough and then smooth when the rpms are raised?
Old Mar 7, 2010 | 10:12 AM
Martin460's Avatar
Martin460
Is the firing order set correct? I`m sure it is...just a idea...
Old Mar 7, 2010 | 11:11 AM
sbsga's Avatar
sbsga
did you say anything bad about the truck when it could hear you, sometimes when i complain about my truck it will take a vacation for a few days by breaking something. keep that in mind, you have to sweet talk it!
Old Mar 7, 2010 | 11:54 AM
cwboyjohnny24
Have you checked out your TPS? Or maybe recalibrate it.
