2nd gen needs help with 20's
Old Mar 2, 2010 | 10:29 AM
rwilhelms's Avatar
rwilhelms
Default 2nd gen needs help with 20's
Alright so Im looking at a set of 20's off a 3rd gen and I know that theyll fit without any problems but I have know clue what size tire I can run on them. How wide are these rims? backspacing offset all that good stuff? I found a set of 305/50/20s on craigslist for a good price and I want to make sure that theyll fit on these rims before I buy them. Thanks for the help
Old Mar 2, 2010 | 11:15 AM
jk360's Avatar
jk360
should be fine with that size
Old Mar 2, 2010 | 11:40 AM
Got_Hemi44's Avatar
Got_Hemi44
I run a 305/50/20. It will be fine.
Old Mar 2, 2010 | 12:02 PM
oefootball_70's Avatar
oefootball_70
My buddy here in Olathe is selling a set of four. One is effed up (more like a set of 3). For like 450 ish I think. PM if you want more info.
Old Mar 2, 2010 | 02:04 PM
HemiLonestar's Avatar
HemiLonestar
20"x9", will fit fine in 2nd gen wheel well. 305/50's are what I have and are about as wide as you should go on a 9" wide rim (10" would be ideal, but not absolutely necessary).
Old Mar 3, 2010 | 01:33 AM
rwilhelms's Avatar
rwilhelms
Thanks for the help guys. Im actully getting a pertty good deal from a guy on craigslist. he selling the rims to me for $400 and then I found a set of lightly used tires for $300 the only thing that worrys me is that one of the tires has a patch in it cause the guy hit a nail in the road or so he says
Old Mar 3, 2010 | 07:25 AM
TexasRam01's Avatar
TexasRam01
I didnt think the 2nd gen's could run a 33" (32.5") tire at stock height??? I'm pretty sure my buddy had to lift his 3" to fit them.
What size are your tires now? I show those trucks came with about a 30-31" tire stock. I dont know what the difference in offset is if any between the stock rims, but you may run into some rubbing issues.... May want to look into it some more.
Old Mar 3, 2010 | 10:19 AM
SlvrRAM05's Avatar
SlvrRAM05
if you need 305/50s I have 2 with 90% tread left hanging in the garage from one of my little oopsies...
Old Mar 3, 2010 | 12:46 PM
rwilhelms's Avatar
rwilhelms
Thats ok cause im putting in a 3 inch coil spacer and 2 inch block in the rear this weekend so i dont think ill have any clearance issues. But the issue I have now is the guy I was gonna but tires from sold them on me so what kind of tires do you guys recomend.
