where to put cut out Wiring in truck?
So I have the raceland cut out and I have all the wiring and box in thr truck but the wiring is going though the back door near the step bars so everytime i open the door the wire gets pinched in. any way to sneak it in the cab. I looked under the truck but no holes or anything. I was going to put it though the engine and then though the firewall but with the fuse and stuff it wont fit. any pics of yours where the wires go. I want the box and everythin in the cab so nothing happens to it lol. Thanks
The switch to open and close are wireless remotes, so I would just want the box and fuses inside the cab. I dont want to cut and run longer wires to much of a pain lol. I was under the truck today where the cut out is but no holes or anything i can remove to put all the wires inside the cab. The power goes to the cigite power thing so all the wires in the cab is what i want. I'll have to keep looking
Hey, I I'll have to check my inbox. I havent gotten a pm from you yet I dont think.
These is no way there. I have looked there and all under the truck and no way. It least I cant find any place. Weried lol
Mine I ran along over the Trans then along the frame to the firewall I did cut my wires so all I had to feed thru the rubber boot that the mine wiring harnes goes in to the cab is the pair of wires. Then in side the truck reattached the wires together and zip tied up out of the way leaving enough of the cig. lighter end to come out by the TRans hump and plug into the power outlet.
