Rear Shackle Question>>>
Subscribe
Mar 9, 2010 | 10:50 AM
Should the rear leaf spring shackle on my truck point down (90 deg angle to the ground) or at a 90 degree angle to the end part of the leaf spring?
I think mine may have moved because one side doesnt seem to match the other for some reason.
Also, should the pivot bolts (ones connected to the spring) be tightened or left a little loose for some movement? thanks
Reply 0
Mar 9, 2010 | 10:35 PM
no one?
Reply 0
Mar 10, 2010 | 12:03 AM
I'll pitch in, my shorty shackle hang down from the spring hanger and attached to the spring at a slight angle. The spring eye is a little toward the rear past what would be perpendicalar to the hanger hole. I always felt that the spring was slightly bunched up because of the really short travel of the shackle. Mine are tight, but they can still move as necessary. If you are binding, try loosening them a little to see if it helps. Good luck...
Reply 0
Mar 10, 2010 | 07:14 AM
Its been so long since I did mine I dont even know any more. sry.
Reply 0
Mar 10, 2010 | 09:02 AM
Quote: I'll pitch in, my shorty shackle hang down from the spring hanger and attached to the spring at a slight angle. The spring eye is a little toward the rear past what would be perpendicalar to the hanger hole. I always felt that the spring was slightly bunched up because of the really short travel of the shackle. Mine are tight, but they can still move as necessary. If you are binding, try loosening them a little to see if it helps. Good luck...
so, the bolts that hold the shackle to the frame are supposed to be torqued, but the pivot bolts that hold the spring to the shackle are supposed to be snug but able to move, correct?
Reply 0
Mar 10, 2010 | 02:36 PM
mine are tight they were when i took em off and when i put my drops in i tightened them again i have no problems.....and yes they push back towards the back of the truck....
Reply 0
Mar 12, 2010 | 06:28 PM
sounds good. thanks
Reply 0
Subscribe
