Programmer: Which one is the best?
Old Mar 9, 2010 | 09:46 PM
councilman's Avatar
councilman
Question Programmer: Which one is the best?
I have a 06 RAM 1500, HEMI. I got a P3497 code, which relates to the MDS system. I suspect that one, or all of the celinoids are bad.
What programmer works best to deactivate the MDS and improves performace at the same time? I have only made one other mod to the truck and that was when I changed over to dual exhaust. I do tow things with the truck (boat, trailer) during the summer months and would like to increase performance overall year round. I have looked at diablo tuner, superchip, bully dog power pup, and a hypertech max power programmer.
Also, I run 87 octane in the truck. Should I be running a higher octane and will the 87 octane damage the engine in the long run?
Old Mar 9, 2010 | 10:12 PM
SilsHemi's Avatar
SilsHemi
The Superchips Flashpaq 3865 will disable MDS. Doesn't sound like you're going to be doing a ton of heavy performance mods, so Superchips will work will for you.
Better performance. Firmer transmission shifts. MDS Disable function. Rev/Speed limiter option. WOT 1-2, 2-3 shift adjustments, tire size option, advance DAQ available as well ( you can monitor a who bunch of PIDS with DAQ).
Sil
Old Mar 9, 2010 | 10:22 PM
councilman's Avatar
councilman
I am quite the newb when it comes to mods. What does "DAQ", "WOT" and "PIDS" stand for?
Old Mar 9, 2010 | 10:29 PM
SilsHemi's Avatar
SilsHemi
DAQ = data acquisition (can monitor stuff like knock retard, etc.)
PIDS = see data acquisition (knock retard is a PID you can monitor)
WOT = Wide Open Throttle (you can adjust your WOT 1-2, 2-3 shifts with the tuner)
You also have a time and distance function. That can be used to record 1/4 mile times.
Sil
