P2299 Code
Old Mar 11, 2010 | 09:23 AM
Adam_MA's Avatar
Adam_MA
Default P2299 Code
So I was goofing around in my truck last night, and I had read about the key trick to pull codes. My truck pulled a P2299. I did a search, and came up with this.
P2299 Brake Pedal Pos / Accelerator Pedal Pos Incompatible
What exactly does that mean, and what is the fix?
I did front brakes in my truck a couple of weeks ago. I was able to compress the pistons back in and reinstalled the pads and new rotors.
Though I have a bad squeek now on the passenger side that I need to pull it back off to find, the pedal seems fine, and the truck stops great. Could the truck have thrown this code from when I was done and had to pump the pistons back into position?
Thanks in advance
Adam
Old Mar 25, 2010 | 01:43 PM
Adam_MA's Avatar
Adam_MA
Just looking back, does anyone have any info on this code? Or possibly a pointer to a web site that I could do some further research?
Thanks
Adam
Old Mar 25, 2010 | 03:04 PM
abarmby's Avatar
abarmby
Yep......you used the "two foot technique".........braked whilst still applying gas.
Pressing the two peddles simultaneously, according to the PSC/computer, are inconsistent with each other.
In the real world, we all know that's not true.........POWER BRAKING Wooo hoooo!!!!
Al.
Old Mar 26, 2010 | 08:28 AM
Adam_MA's Avatar
Adam_MA
Ahhhh... So this code is probably left over from before I got rid of the factory crapyear tires, and though it would be funny to get the rear tires to hit the speed limiter, while sitting still!!! Good times!!!
