Replacing Under Hood light bulb
Old Apr 30, 2005 | 10:57 AM
mill500's Avatar
mill500
Default Replacing Under Hood light bulb
Kind of a dumb question, but my underhood light is out. Has anybody had to replace one of these bulbs? I was pulling around on it trying to figure out how it comes apart (there's nothing in the manual I could find on it). It looks like the only 2 possibilities are the plastic lens itself and the electrical connector, but niether seem to want to come apart and I don't want to start prying on the wrong part and break the thing (been there done that before).
Old May 1, 2005 | 01:26 AM
Parts/Service's Avatar
Parts/Service
Default RE: Replacing Under Hood light bulb
REMOVAL
Disconnect and isolate the battery negative cable.
Insert a small flat blade in the access slot between the lamp base and lamp lens.
Pry the lamp lens upward and remove the lamp lens (Underhood Lamp Lens).
Depress the bulb terminal inward (Underhood Lamp Bulb) to rele
