New plugs, Clean TB, Synthetic oil=worse mpg's
#21
Jammen- Nope, sure haven't. Would that really throw the mpg's off.....that much anyways?
Red- Whats happening my friend? They didn't really take me by surprise, I knew I'd lose something. More weight + larger rotating mass= gonna hurt somewhere. Just the laws of Physics I reckon.
I think I'm not so much frustrated with the tires causing the loss in mpg's, its more so the maintaince not helping, but actually hurting the situation. Like I said, I lost a mpg or so after the tireswap, and another 1-1.5 since the maintaince....
#22
If you never had the tire size re-calibrated in the truck and put bigger tires on it, then the truck is incorrectly recording the miles driven. After going up 2 tire sizes my speedo was over 5mph at 70, the speedo would read 70, but I was actually doing 75. That means I would drive 75 miles, but the truck would only log 70 on the odo. I would check to see if your speedo is off with a gps or something, cuz if it is then that could hurt the mileage calc.
And +1 to whoever said calibrate the TPS, when I cleaned my TB the rpms would jump around like crazy till I re-calibrated it.
#23
Yeah, I went from 245-70's to 295-70's, so not a huge difference, but enough I guess. I used a calc, I think posted by Jon or Jay, that said I was off by about 7mph, roughly of course. I'm guessing thats a dealer fix, since I can't go the tuner route as of now....
Is that what it would take, a StarScan computer? Or could a Snap-on diagnostics computer do it? I doubt it, that'd be too easy for me, lol. Then I could just get the ol' man to do it for me, his shop has all the new fancy Snap-On stuff....
Thanks for the help again guys, I might just do the "tricks" tomorrow, for the hell of it. I have a 1/2 tank right now, so I could tell enough of a difference with that, if there will be any.
#25
First of all, forget the O/H console. The only way to properly determine gas mileage is to fill it to the brim (not pump cut-off), drive it, fill it to the brim again. Then do the math. And yes, tire size will affect the apparent miles driven.
#26
#27
Your new tires will throw your speedo off by 8.29% which as noted above throws your odo off by the same amount. Then you figure your rear-end ratio is changed to 3.60 if you have 3.92's so your making more work to get moving in town. Try adding another 8% or so to your mileage when calculating. I called a dealership about getting a speedo recalibrate done for my tires and it was $50 so I just went with a superchips.
#28
BTW, filled to the brim is likely more than 26 gallons. A Chevy 1500 I had with a 35 gallon tank held 37.3 when filled to the brim from a sputtering stop.
#30
