3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Will it work? I know 02-06 are the same? & the 06 fit but what would I have to modify to make them work? I really hate the bubbly 07-08 tails, they make it look like it should have a bowtie badge :-P
Yeah might just have to do that. I was hoping that the nightshaded tails and 3rd brake light that 05dodgeramhemi had for sale would fit. Owell thanks anyway Marx
The 02-06's have different pigtails/wiring than the 07/08's. You would just have to do a little splicing is all, but they are a direct swap as far as the molds go. Meaning they fit in the rear quarters perfectly.
You sure the splicing will work right? The 02-06 use the upper bulb for the turn signal and the lower bulb for brake lights. Will this not cause some feedback thru the circuits since the 07-08 only uses one bulb for both?
LED's are the best way to go.
