3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
BTW, did you use that steering extension and what other parts did you not use. I ask because I know i didnt do my e-brake bracket or my fuel filler.
Doing a BL is not a simple and quick job. Sp anything to save time helps.
Yeah I used the steering extension. I was having trouble getting my steering shaft to slide up and down. Once I got it moving it was no problem, thanks for the help BTW. I didnt modify my fan shroud because I have a e-fan mounted inside the stock shroud. I didnt do the E-Brake bracket or the fuel filler extension either. And man Ill tell you, don't do this job by yourself! Its not really a hard job but if you got somebody to help out it will make it a lot faster. Thanks everybody for the compliments. Yalls opinions mean alot to me. V_Scapes I think you have always been my #1 fan, Thanks man! Just trying to catch up to WEED!!
It looks great, Bear. And I don't think you need bigger tires, you're 33s look perfect on there, I think 35s would look a little stuffed.
I don't know man, I got 11 inches clearance from the tire to the fender in the front and 11.5 in the back. I am definatly going to ride on these tires for a while tho, too much tread left to get new ones now.
