flooding problem
Old Mar 18, 2010 | 09:13 PM
jhall347's Avatar
jhall347
im still not sure on the duty cycle, but i did check the injection pulse by putting a light in the inj. plug and crack the engine. the light looked like a strobe light with irregular pauses. so i then checked the CMP connector. now i was told 1 wire is ground, 1 is signal (no power), and 1 has 5 volts (with key on). i have 1 grd. and both wires have 5.2 volts. so i followed the wires back and found the sig. wire and the AC comp. power wire were rubbing together. i repaired both wires and still have the same problem. i followed the CMP sig wire back to the PCM and cut the wire to see if the pcm was sending out voltage, and it is, 5.2 volts. am i right on the signal wire should have 0 volts? and does this mean my pcm needs replaced? sorry so long
Old Mar 19, 2010 | 01:08 AM
HouseApe's Avatar
HouseApe
You should not have 5 volts on the CMP Signal. If you do then you have a short to the 5 volt ref. So you cut the Sig wire at the ECM and still get 5 volts ? If yes ECM is done.
Old Mar 19, 2010 | 01:15 AM
jhall347's Avatar
jhall347
so you believe i need a new ECM? do you know of anywhere that i can get one? i bought this truck with this problem, (i know you can laugh but i got a good deal) the guy i bought it from rebuilt the motor, you dont think it could be a damaged cam sensor ring? i order it and can pick it up in the morning, but i never paid for it yet.
Old Mar 19, 2010 | 01:19 AM
jhall347's Avatar
jhall347
sorry didnt read your question right. i did cut the signal wire at the pcm and i do get 5 volts coming out of the pcm.
Old Mar 19, 2010 | 11:08 AM
HouseApe's Avatar
HouseApe
Just to be clear the cam sensore has three wires
1 DB/GY CMP SIGNAL (from Sensor to ECM) is this the wire you cut and got 5 volts on the ecm side ? If yes ECM is shorted internally.
2 DB/DG SENSOR GROUND
3 YL/PK 5 VOLT SUPPLY (from ECM to Sensor)
You can get on at a junkyard or check with your local parts store too as they sell remaned units. Just make sure its the same Part Number.
Old Mar 19, 2010 | 02:58 PM
jhall347's Avatar
jhall347
thanks for all your help, ill try to order one this weekend.
Old Mar 19, 2010 | 04:31 PM
dirtydog's Avatar
dirtydog
Moderate User
Check this out.
For the cam sensor, have you tried checking the resistance?
Old Mar 20, 2010 | 12:39 PM
HouseApe's Avatar
HouseApe
Wont matter as he says he cut the sig wire at the ECM and got 5 volts at the ECM side of the wire.
Most likely the short to the A/C clutch wire killed the ECM.
Old Apr 8, 2010 | 10:36 PM
jhall347's Avatar
jhall347
ok i finally got my new ecm today. and the truck is still doing the same thing? i went thur the whole engine harnes to check for anymore bad wires, and everything looked good. i did pull all 6 plugs out and hooked the coils to them, just to watch how they spark. and the driverside of the motor (all 3 plugs) seems to sparking at the same time. im lost
