How do you guys add diff fluids?
Old Mar 14, 2010 | 11:28 PM
rocket23's Avatar
rocket23
Originally Posted by Shiloh 24
I didn't use anything when I did mine, the tip on the Royal Purple bottle was long enough I didn't need to use anything and Senseless even though it wasn't cheap I put Royal Purple in mine.
Just the guy I am looking for. how did you wire the woofer/kicker in your truck i have two ten inchers I wanna use how do I ty in too the components???
Old Mar 14, 2010 | 11:56 PM
JoeHemi's Avatar
JoeHemi
Off topic maybe? HAHA
Senseless, most info you can find up in the FAQ section. Also, if you go to Amsoils website and enter in your info, it will give you capacities and types. This is another great site to visit.
To the OP; I just used Mobil 1 full syn in the diffs. The bottle, like RP, has a tip on the end. I just snipped off the end and the bottle itself acts like a funnel.
Old Mar 14, 2010 | 11:59 PM
senselesscreationz's Avatar
senselesscreationz
ok so i need 75w-90 probably go with RP but how many do i buy? cant find that info
Old Mar 15, 2010 | 12:00 AM
Shiloh 24's Avatar
Shiloh 24
I'll answer that in a pm or if you have any type of instant messenger, I have about all of em. Senseless I recommend 75 - 140 for the weight and the bottle will of course be purple and called High Performance gear oil. Two bottles filled my rear diff on the dot to where it's sposed to be, your rear should be the same and your front I don't have a clue. 4x4 is not something I have alot of knowledge about let alone IFS 4x4's.
Old Mar 15, 2010 | 12:03 AM
senselesscreationz
ok so just remove the plug and fill or take the diff covers all the way off?
Old Mar 15, 2010 | 12:05 AM
JoeHemi's Avatar
JoeHemi
You need to take the diffs off to drain old oil since there is no drain plug. Then after reattaching the diffs, you use the fill hole to refill with fluid.
Old Mar 15, 2010 | 12:06 AM
Shiloh 24's Avatar
Shiloh 24
You gotta pull the covers to let the oil out, then you can inspect everything clean it all up and then replace the cover with a nice new coat of RTV sealant. Then let the sealant setup a bit and fill her up.
Old Mar 15, 2010 | 12:09 AM
JoeHemi's Avatar
JoeHemi
Here look at this. It will give you an idea on what to do. Its the same process for the most part, just this is an example on a 2WD 10.5 diff so it holds a bit more fluid. Your 9.25 rear takes around 4.9 pints according to amsoil.
Old Mar 15, 2010 | 12:12 AM
rocket23's Avatar
rocket23
yeah 24 hrs for a full cure 90 weight in both oughta do it give your self a treat and paint the covers might as well gonna sit for 24 hrs anyway plenty of time too dry. silver is cool chrome paint i've seen and also engine red high gloss looks sweet
Old Mar 15, 2010 | 12:18 AM
dirtydog's Avatar
dirtydog
Moderate User
I use a suction gun. Holds about 3/4qt. I can squirt fluid in a hole above the muffler and through the floor if I had to....lol
Paid $15 for it
