Hella 500's Sucking Juice from my Battery
Old Mar 16, 2010 | 04:48 PM
A05GSHO's Avatar
A05GSHO
Default Hella 500's Sucking Juice from my Battery
I'm not a wiring guru here, but it seems since the relay switch fried last summer on my Hella's and I replaced it with the same one from Hella there draining my battery. Deader than a door nail if it sits for 2 weeks. Any ideas why?
Like I said I'm not a wiring guru how do you hook them up directly to the toggle switch? I had them hooked up the the bright lights.
Old Mar 16, 2010 | 05:29 PM
BadHab1t's Avatar
BadHab1t
wire from battery to a fuse wire to the switch and wire back out to the hellas i would assume thats how i have lights hooked up...i have no issues as long as i shut the switch off...
Old Mar 17, 2010 | 12:48 AM
gasguy's Avatar
gasguy
Your Superchips has a substantial draw, especially if sitting for a couple of weeks.
Old Mar 17, 2010 | 12:50 AM
gasguy's Avatar
gasguy
.... Deader than a door nail if it sits for 2 weeks. Any ideas why?
Your tuner will use quite a bit of juice during those two weeks, consider a trickle charger or something of the sort.
Old Mar 17, 2010 | 12:59 AM
JoeHemi's Avatar
JoeHemi
He's talking about off road lights behind the grill. Also, a superchips plugged in will kill your battery in less than 2 days. I know from experience.
Old Mar 17, 2010 | 06:31 PM
A05GSHO's Avatar
A05GSHO
I don't keep the Superchips tuner plugged in. I set it at performance, set the shift points, the tire size, top MPH and unplug it.
