ABS Brakes
Old Mar 17, 2010 | 11:01 PM
05_hemiram's Avatar
05_hemiram
Default ABS Brakes
Are ABS brakes standard on 2005 1500 SLT's or were they an option? I have a 40A fuse under the hood for "ABS Pump" but i definitely didn't have ABS brakes this past winter haha.
Old Mar 18, 2010 | 01:03 AM
Marx's Avatar
Marx
i think 2 wheel ABS is standard, i have an SLT and it says 4 wheel ABS as an option on my buy sheet
Old Mar 18, 2010 | 02:59 AM
RedTruck-VA's Avatar
RedTruck-VA
My 03 base model SXT 2wd has ABS, so I am thinking it comes standard.
Old Mar 18, 2010 | 07:52 AM
MOusafLRT03's Avatar
MOusafLRT03
i believe it's standard, but ithink i need to check my fuses when i get a chance cause i most definitely had no ABS whatsoever...even rear. i had rear ABS in my other 03 and it worked quite well, but this one, totally different story. oh, and also, i noticed the ABS sensor ring inside the rear end.
Old Mar 18, 2010 | 09:18 AM
RedTruck-VA
The rear tone ring also provides VSS input.
Old Mar 18, 2010 | 10:26 PM
chrisy1961's Avatar
chrisy1961
2 wheel ABS is standard and 4 wheel ABS was an option on my 2004. Mine has 2 wheel ABS. I needed a part that was 2 wheel or 4 wheel ABS specific. I only know because I had to call the dealer and ask them using my VIN number in order to get the correct part. I didn't get a printout but they always answer my questions when I call as long as I can give them my VIN.
