Key question & back seat question
Old Mar 21, 2010 | 05:46 PM
canadian wheeler's Avatar
canadian wheeler
My rear seats do the same thing. From what i read on other threads there is probably something jammed in the hinge or the hinge might be rusted. Most guys seem to fix the hinge with a big flat head screw driver.
Old Mar 21, 2010 | 06:29 PM
LinerJoe's Avatar
LinerJoe
If you have 2 existing (functional) key/remotes, you can buy one off of ebay and program it. If you only have 1 working key, then the dealer will have to do it for you.
joe
Old Mar 21, 2010 | 06:35 PM
canadian wheeler
This thread just inspired me to fix my back seats. Its hard to explain but i will try. There is a disc that is notched in the middle of the hinge for the seats which was stuck in place. Every time my seat tried to rotate up it would hit the disc. The disc should move freely. I took some wd40 and sprayed the disc and work it up and down for a few mins and it loosened up. FIXED! Hope this helps.
Old Mar 21, 2010 | 10:32 PM
ThuDLux1's Avatar
ThuDLux1
canadian, thnx.... when i get off of work tomorrow i am gonna tackle this.... it's not a real big deal to start w/ cause i don't know what i need under the seat for, but it's jus the principle of it......
i will let all of you know if i get this fixed...
and about the key, i only have one.... i found one on ebay for 16 bucks... dealership said they will program it for 38 dollars... that's not as bad as it could b...
thanks for all of ur help....
Old Mar 22, 2010 | 09:32 AM
cheezy66's Avatar
cheezy66
if you have 2 programed keys, you can order transponder keys of the net or ebay. have your local hardware store cut the keys. then follow the manual to program the new transponder keys. very simple to do, but you must have 2 transponder keys to program any extras. you can program up to 8 keys. i've had to do this on my liberty, grand cherokee, and now my 07 ram. i got my keys for $15/ key, and that included shipping! my dealer charged me $200 for a remote key and programing. never again!!
Old Mar 22, 2010 | 10:06 AM
ThuDLux1's Avatar
ThuDLux1
that's about right... i bought a transponder key for 16 bucks and the dealership said they would program it for 38 bucks.... then i will have two keys that will start my truck....
Old Mar 23, 2010 | 11:26 AM
cheezy66's Avatar
cheezy66
i did a little experiment yesterday. i took an unchipped key and put it in the ignition. then i took my programed key and moved it around the steering column until the truck started and stayed running. theoretically, i could tape/glue my key here, and just use a regular key all the time. like i said, just messing around.
Old Mar 24, 2010 | 09:24 PM
ThuDLux1's Avatar
ThuDLux1
UPDATE UPDATE
cheezy, i done the same thing and couldn't get the truck to stay running with the unchipped key in the ignition and the chipped key stacked on the unchipped and all around in the cab..... any who, waiting on new transponder key to arrive to make a spare ignition key..
canadian, finally got the seat to work. i found the piece u were talking about and i sprayed to heck out of it and worked it for a bit and then the seat would still bind up.... tried spraying it again and working it some more and it is like brand new now..... now my cab smells like spray lube.... LOL.... it's all good tho...
thanks so much for yall's help n info....
thudlux1
