finally...but a problem
Old Mar 19, 2010 | 08:41 PM
HemiPro_05's Avatar
HemiPro_05
Default finally...but a problem
finally put on the pacesetter lt's. I had to extend the driver side rear o2 sensor and just soldered the connections together. Now it shows code p0037 and wont pass inspection. Do you guys think I just made poor connections on that or what?
Old Mar 19, 2010 | 08:45 PM
rocket23's Avatar
rocket23
wow I'm lost these pace setters are what exactly headers??
Old Mar 19, 2010 | 08:51 PM
ramhunter9's Avatar
ramhunter9
yes they are headders , and check your connections make sure they are the same distance away from the cat as stock
Old Mar 19, 2010 | 09:19 PM
HemiPro_05's Avatar
HemiPro_05
i think i may have found the problem but wont be able to find out for a couple days....When I soldered the wires together I wrapped them up together instaed of individially and i think all the connections are touching eachother.... and how they hooked it up its just about impossible to get to that o2
Old Mar 19, 2010 | 09:25 PM
ramhunter9's Avatar
ramhunter9
that will do it .
Old Mar 19, 2010 | 10:01 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
What is code p0037? When I installed my Pacesetters I got a code for low voltage in the downstream o2 sensor, not sure if that is what your code is. Had to do the nonfouler trick to get rid of it.
Old Mar 19, 2010 | 10:03 PM
HemiPro_05's Avatar
HemiPro_05
^^^^^^^ thats my code right there but when I cross is it says wiring problem....
Old Mar 19, 2010 | 10:05 PM
Off_Road_Teacher
Did you change the cats to high flows?
Old Mar 19, 2010 | 10:11 PM
HemiPro_05's Avatar
HemiPro_05
there not really high flows just about the same as stock just more convient sizing
Old Mar 19, 2010 | 10:13 PM
Off_Road_Teacher
Well you might want to try the non fouler trick if the cats are smaller than stock.
