biggest rim/tires 05 ram 2500 (exhaust, air filter intake)
hey i got a 05 ram 2500 QC HEMI...... was told i could fit 20"rims w/ 33" tires no need to lift and no rubbing, but dont kno how wide of a rim i should get.. also what exhaust should i get (i no ive heard some exhaust actualy loose power, also which intake should i get....???? any help would be appreciated............
my e-mail is bpunk360@aol.com feel free to im me or e-mail me i could really use the help
i think ou should be able to get 35" on without any rubbing. As for how wide, i wouldn't really want to go any wider then you have now or they will stick out.
ORIGINAL: cowboy133
my 2500 quad cab has 35x12.5x17's on it. No rubbing at all. Love the Cummins too.
You have the cummins, which the diesels have a slightly larger and stiffer coil. (not sure how much higher)
As far as the 33's go...yeah, you'll fit them no prob.
//edit//
Also, the rim size in width....not sure about 20's but 17's (smallest rim you can use) mostly come in 9"wide or 10" wide so a 12.5" wide tire will do fine.
ORIGINAL: rob[GL]
where do you guys find mud-rubber for a 20-inch rim?
I love the tread pattern on these
Most 20" off-road tires will be a 35" or larger. I haven't found a 33" yet.
thanks guys apreciate the info. im just gunna do 33"s (by 12.5" wide) on my 17" stock rims (to broke to get the 20's i want).......
Trending Topics
iirc aren't most stock wheels 7-7.5" wide?
And if you're looking for an off-road tire because you're actually going to go off-road, leave the 20's for the posers. They'll hurt your off road performance unless you're running 40"+ tires.
i have the stock 17" i wann put bigger tires on b/c i cant afford new rims plus i have the better 17"s i kinda like them. so whats the widest tire i can put on the stock 17"s ..............a 10" tire????
