Best Oil Filters
Old May 16, 2005 | 11:25 PM
Hemi Dave's Avatar
Hemi Dave
Default Best Oil Filters
Go to the site below and check out the oil filter study. Looks like AC Dura Guard, Purolator Pure 1 and Mobile are the way to go. Fram seems to be the worst. This guys testing makes a lot of sense. Also read the story about the Mopar Filters...not what they may seem to be.
http://www.minimopar.knizefamily.net
Old May 17, 2005 | 12:20 AM
moparturd's Avatar
moparturd
Default RE: Best Oil Filters
Couldn't get the link to work.[&o]
Old May 17, 2005 | 01:03 AM
osteodoc08's Avatar
osteodoc08
That site has been ciculating around here for a while. It is a good study although a few years old. I usually use Wix, Mobil, or K&N filters although the Fram ToughGard aren't that bad.
Old May 17, 2005 | 10:03 AM
Drew's Avatar
Drew
Fleetguard Stratopour for mine.
Fleetguard is actualy a division of Cummins, so I'm making sure I dont void the warranty
Old May 17, 2005 | 01:53 PM
WingViper's Avatar
WingViper
I did my second oil change the other day on my Ram and after reading a bunch of threads decided to switch from crude to synthetic and go with Mobil 1. I buy a filter and the oil and head home. I wake up the next day and start working the switch, get the oil filter off and oil drained good, when I go to put on my Mobil 1 filter, and lo-and-behold there are METAL shavings in my new Mobil 1 filter! I was LIVID. Looking closer I found glue around the gasket all over the place and dents and dings in the inner walls. I was able to get a ride back to the store (Autozone) and switch it out with another Mobil 1 filter that passed inspection but even the store manager was surprised that a bad filter had come from Mobil 1. I plan on seeing how this change comes out, but definitely check your filters before purchase. My family has used Frams for as long as I can remember and never had a problem, and even the Autozone guys said Fram is a good brand, but maybe they haven't seen these tests. Just laying out my experiences.
Old May 17, 2005 | 04:11 PM
osteodoc08's Avatar
osteodoc08
I check all the filters I get before I buy them. I look for crap in them (such as shavings from the processing of the can and threads), dents and dings, and most importantly that it is the correct part number! I have seen boxes where some idiot switched them. Also seen this in air filters where some low life takes a K&N and puts it in a regular box so he gets it for a few bucks cheaper. I have seen more sitcheroos than anything.
I've learned to not trust some of these peoples' opinions. Some know much, most know as little as what the computer in front of them tells them. Fram is NOT BAD, it is just there are BETTER choices. I do run thier ToughGard line of filters though if the Mobil or PureOne isn't available. I'm not a fan of thier regular Orange filters or the ones with Teflon in them. Engine longevity comes down to maintenance, pure and simple. I knew a guy that ran plain dino for about 12K miles because he was "too busy" to have it changed and the motor seized up on him from blocked passages. I've also had friends that change every 3k miles and have over 250K miles. It doesn't run like new, but it does run and start when he needs it too.
And for the people that balk at spending $35-40 for a synthetic change with premium filter. Look at how much money in gas you've spent to get to that 3K miles. Lets see: 3000/15mpg is 200 gallons of gas 200x$2 is $400. I stretch my synthetic over 5K miles so the value is even greater. Just doesn't make sense to me to cheap out on maintenance.
Old May 17, 2005 | 11:39 PM
mill500's Avatar
mill500
I've read quite a few of the reviews as well, and most come down pretty hard on Fram. They don't like the bypass, have inferior filter media, and have been documented to actually have found cigarette butts inside when cut open (true story---not urban myth). The best reviews I've found are on Wix, NAPA Gold and Mobil 1. I usually bounce back and forth between the Wix and Napa depending on which parts store I'm going by when I'm ready for a change. Never have tried the Mobil1 filter, but use the oil all the time.
