I've got a Coolant Leak!! I need some help...
Old Mar 22, 2010 | 10:32 PM
04LS6's Avatar
04LS6
Default I've got a Coolant Leak!! I need some help...
Hey guys,
I have been looking and found where my coolant leak is coming from. I'm actually pretty happy about where the leak is, because I think it's a pretty easy fix. Where it's leaking is on the outlet of the block, right where the flange from the rad hose connection is connecting to the block above the powersteering pump. What I need to know is, is there a fiber gasket in between these surfaces? Also, should I also replace the flange that attached to the rad hose as well at the same time?
One other thing that I need answered is, I've never drained coolant before, so when draining, is the drain on the bottom on the drivers side? Is it that black plastic looking nipple that can be turned with a small drain hole underneath it? When filling, how do I get all of the air out of the system?
Sorry for the long winded email, but I'm really just wanting to get this fixed, and done right...lol Thanks guys.
Old Mar 23, 2010 | 06:54 AM
cwboyjohnny24's Avatar
cwboyjohnny24
That's where your thermostat is. If it were me, I would just buy a new thermostat (pretty cheap) and they normally come with a new gasket. Just change out the thermostat while you're there. That's one less thing you have to worry about. And yes, the drain **** is that "plastic looking nipple."
