spark plug non-foulers
Old Mar 24, 2010 | 07:15 PM
BAnders's Avatar
BAnders
Default spark plug non-foulers
what size non-fouler would i need for my 04 5.7? i went to jotozone(autozone) and they only had 14mm and 18 mm. im about to do that trick to my down stream o2's. and will the cel go out by itself once i do the trick or do i have to clear it with the scanner
Old Mar 24, 2010 | 07:17 PM
OlDirtyJohn's Avatar
OlDirtyJohn
dont know what size you need, but you will need to clear the code either with a scanner, or disconnecting the battery for a while.
Old Mar 24, 2010 | 07:18 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Check out the FAQ, it has a ton of info. Here's just a little light reading for ya.
https://dodgeforum.com/forum/3rd-gen...ving-cats.html
Old Mar 24, 2010 | 07:34 PM
HammerZ71's Avatar
HammerZ71
Get them to pull an O2 sensor for your truck from stock and match up the size/thread pattern...
Old Mar 24, 2010 | 10:50 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
you need the 18mm and they are 1.5 pitch. So you need the 18mm x 1.5
Old Mar 25, 2010 | 01:33 AM
rickof08's Avatar
rickof08
Ive never thought to do this but i read the writeup. So you have to do this to the postcat sensor?
