4wd Low doesnt work HELP
Old Mar 24, 2010 | 09:20 PM
crazyandy202's Avatar
crazyandy202
Default 4wd Low doesnt work HELP
I recently bought a 2006 Ram 1500 4.7L and my 4wd works but when I go to put it into 4wd Low it doesnt turn over it just blinks. What could be wrong? THanks for your help!!!
Old Mar 24, 2010 | 09:39 PM
nussdawg395's Avatar
nussdawg395
Mine does the same thing. If you read in your book it tells you that it has to synchronize to get into 4low. I usually engage 4low while stopped in neutral and if it doesnt go in i try and pull forward and reverse a little bit very slowly and it will engage. Sometimes you have to play with it a bit between park, drive, neutral, and reverse. You'll figure it out once you play with it but it can be a pain sometime tho.
Old Mar 24, 2010 | 10:40 PM
crazyandy202
It worked thank you so much!
